Виж темите без отговор | Виж активните теми Дата и час: Чет Мар 28, 2024 7:09 pm
Отговори на тема  [ 130 мнения ]  Отиди на страница Предишна  1 ... 3, 4, 5, 6, 7
 foresterclub.gr
Регистриран на: Пет Сеп 09, 2011 10:16 pm
Местоположение: Athens
O.k, i will.
My turbo is GT3076, but with 0.70A/R aluminium from GT35 for 600 hp, not with 0.60 A/R like usual GT3076.
It has very good spool and power up to rpm cutter.
http://www.turbomaster.info/eng/applica ... 9-0002.php
Вто Мар 18, 2014 4:15 pm
Here my specs:
MOTOR
Close deck 2.5 block with arrow rods, je pistons, acl bearings
sti 06 motor heads ported
Garrett gt3076 rotated turbo
cosworth head studs
cobb 76mm exhaust
custom downpipe and up-pipe
tomei equal header
dgv delete
greddy air intake
Coyo radiator
setrab oil cooler
Greddy f/m intercooler
aeromotive 340 fuel pump
aeromotive fuel rails
sti group N motor mounts
tomei oil baffle plate
TRANSMISSION
6MT from impreza spec-c 2004 with dccd and helical lsd front-cusco 1,5 way rear
exedy carbon twin clutch
BRAKES
Prodrive (alcon) 330mm 4pot front with ferodo ds2500
stock sti brembo 326mm 2pot rear with ferodo ds3000
GAUGES
avcr boost controller
turbo pressure
oil pressure
oil temp
exhaust temp
fuel pressure
scangauge for water temp and inlet air
innovate wideband
SUSPENSION
BC coilovers for all season
sti 20mm rear sway bar
greddy front strut Tower Bar
cusco rear strut Tower Bar
TYRES
federal semi slick 235-40-18 for summer
and sti 07 steering rack.
I am sure i have forgotten some things....
Вто Мар 18, 2014 4:18 pm
Местоположение: Planet Earth
Автомобил: V8 bi-turbo
Yap, nice... a "very slightly" modified Forester :D
Вто Мар 18, 2014 4:40 pm
Автомобил: EA839,MA1.20
What about the seats, you still use stock sofas or... :)
Вто Мар 18, 2014 9:49 pm
For the time i have the stock seats.
Next move is a bucket.
Вто Мар 18, 2014 10:02 pm
stolis написа:
Here my specs:
Stolis, where on the rev meter comes your boost with this 'modded' GT3076?
Сря Мар 19, 2014 1:04 am
Изгонен
:good:
SUBARULAND Ltd
0878 207 541 - Красимир
0899 612 719 - Венци
Сря Мар 19, 2014 2:25 am
=Alex= написа:
stolis написа:
Here my specs:
I have good power from low rpm and full boost about 4.000.
Сря Мар 19, 2014 6:32 am
Регистриран на: Пон Апр 14, 2014 3:12 pm
Skype: vankataaa2
Hi ! I am interested in buying an impreza from greece Could you support me with the viewing of the cars because I need an expert opinion ? I want to know what is the procedure about the documentation and the changing of the owner ? Here are the cars I would like to look at : http://www.car.gr/classifieds/cars/view/2725466/ http://www.car.gr/classifieds/cars/view/4295766/ http://www.car.gr/classifieds/cars/view/4972100/ . We managed to contact just to the first car and the car is available and can be checked. We have contacted all the cars and we can take a look at them. They are in Athens .
Сря Апр 16, 2014 12:36 pm
Only the last car is in Athens.
Сря Апр 16, 2014 6:24 pm
Иди на:
