stolis
Регистриран на: Пет Сеп 09, 2011 10:16 pm Постове: 60 Местоположение: Athens Рейтинг: 27
Вто Мар 18, 2014 4:15 pm |
stolis
Here my specs:
MOTOR Close deck 2.5 block with arrow rods, je pistons, acl bearings sti 06 motor heads ported Garrett gt3076 rotated turbo cosworth head studs cobb 76mm exhaust custom downpipe and up-pipe tomei equal header dgv delete greddy air intake Coyo radiator setrab oil cooler Greddy f/m intercooler aeromotive 340 fuel pump aeromotive fuel rails sti group N motor mounts tomei oil baffle plate TRANSMISSION 6MT from impreza spec-c 2004 with dccd and helical lsd front-cusco 1,5 way rear exedy carbon twin clutch BRAKES Prodrive (alcon) 330mm 4pot front with ferodo ds2500 stock sti brembo 326mm 2pot rear with ferodo ds3000 GAUGES avcr boost controller turbo pressure oil pressure oil temp exhaust temp fuel pressure scangauge for water temp and inlet air innovate wideband SUSPENSION BC coilovers for all season sti 20mm rear sway bar greddy front strut Tower Bar cusco rear strut Tower Bar TYRES federal semi slick 235-40-18 for summer
and sti 07 steering rack.
I am sure i have forgotten some things....
Вто Мар 18, 2014 4:18 pm |
=Alex=
Yap, nice... a "very slightly" modified Forester
Вто Мар 18, 2014 4:40 pm |
bubaru
What about the seats, you still use stock sofas or...
Вто Мар 18, 2014 9:49 pm |
stolis
For the time i have the stock seats. Next move is a bucket.
Вто Мар 18, 2014 10:02 pm |
=Alex=
stolis написа: Here my specs: ... Garrett gt3076 rotated turbo
Stolis, where on the rev meter comes your boost with this 'modded' GT3076?
Сря Мар 19, 2014 1:04 am |
agent dust
Изгонен
Сря Мар 19, 2014 2:25 am |
stolis
=Alex= написа: stolis написа: Here my specs: ... Garrett gt3076 rotated turbo
Stolis, where on the rev meter comes your boost with this 'modded' GT3076? I have good power from low rpm and full boost about 4.000.
Сря Мар 19, 2014 6:32 am |
Alcos
Регистриран на: Пон Апр 14, 2014 3:12 pm Постове: 9
Skype: vankataaa2
Сря Апр 16, 2014 12:36 pm |
stolis
Only the last car is in Athens.
Сря Апр 16, 2014 6:24 pm |
