Самодиагностика и диагностика Субару
agogov
Автомобил: Forester 2.0 MT
Последна промяна agogov на Пон Мар 08, 2010 7:48 pm, променена общо 1 път
| Чет Дек 10, 2009 6:49 pm |
agogov
| Чет Дек 10, 2009 6:54 pm |
gorogoro
Регистриран на: Сря Дек 10, 2008 7:01 pm Постове: 879 Местоположение: София
Автомобил: Legacy 2.5 AT '01
Давай таблиците  ... и слагай темата направо в "Златния фонд"!
| Чет Дек 10, 2009 8:32 pm |
BAlexandrov
Самодиагностика АКПП необходима в случае если после старта двигателя лампа POWER мигает 16 раз. Оригинал: To perform the self diag test for EXISTING problems 1) Warm up engine by driving at speeds greater than 12mph. 2) Stop vehicle and turn ignition switch OFF. 3) Turn ignition switch ON and make sure POWER indicator lamp comes on. 4) Turn ignition switch OFF. 5) Move selector lever to D and turn manual switch ON. 6) Turn ignition switch ON. 7) Move selector lever to "3" and turn manual switch OFF. 8) Move selector level to "2" and turn manual switch ON. 9) Move selector lever to "1" and turn manual switch OFF. 10) Partially depress accelerator pedal (to turn idle switch off). 11) Check code as displayed on POWER light. Blinking once every 1/4sec is normal.
To perform the self diag test for PREVIOUS problems 1) Warm up engine by driving at speeds greater than 12mph. 2) Stop vehicle and turn ignition switch OFF. 3) Turn ignition switch ON and make sure POWER indicator lamp comes on. 4) Turn ignition switch OFF. 5) Move selector lever to "1" and turn manual switch ON. 6) Turn ignition switch ON. 7) Move selector lever to "2" and turn manual switch OFF. 8) Move selector lever to "3" and turn manual switch ON. 9) Move selector lever to "D" and trun manual switch OFF. 10) Partially depress accelerator pedal (to turn idle switch off). 11) Check code as displayed on POWER light. Blinking once every 1/4sec is normal.
Trouble codes: 11 Duty solеnoid A 12 Duty solеnoid B 13 Shift solеnoid 3 14 Shift solеnoid 2 15 Shift solеnoid 1 21 ATF temp sеnsor 22 Atmospheric sеnsor 23 Еngine revolutiоn signal 24 Duty solеnoid C 25 Еngine torque control signal 31 Throttle sеnsor 32 Vehicle speed sеnsor 1 33 Vehicle speed sеnsor 2
Моя отсебятина: 1 прогреть жидкость в коробке, т.е. можно либо специально поездить не менее 20 км/ч либо заниматься диагностикой после поездки. 2 заглушить двигатель 3 завести двигатель подождать пока примигает 16 раз POWER и заглушить двигатель 4 селектор перевести в положение D и включить AT hold 5 включить зажигание, не заводить. 6 селектор перевести в положение 3 и выключить AT hold 7 селектор перевести в положение 2 и включить AT hold 8 селектор перевести в положение 1 и выключить AT hold 9 педаль газа нажать в пол 10 считаем мырганья POWER длинный мырг - десятки, короткий - единицы. Т.е. два длинных четыре коротки означает код ошибки 24 - Duty solеnoid C. Отсебятина - это как я делал на своей машине Subaru Legacy TS-R август 1996 года выпуска, в том числе и ошибка frown.gif Заметьтте, что есть некоторые несоответствия оригиналу. <u></u>
Тестирование коробки (OBD-II) на авто после 98-го года:
1. Включил зажигание 2. Выключил зажигание 3. Включил зажигание 4. Селектор в положение 1 5. Выключил зажигание 6. Включить зажигание 7. Селектор в положение 2 8. Селектор в положение 1 9. Селектор в положение 2 10. Селектор в положение 3 11. Селектор в положение Д
Смотрим на индикаторы, считываем коды...
Если ошибок несколько, то он между ними делает паузу. Выдавать коды будет до тех пор, пока не выключите зажигание или не посадите аккумулятор.
11 - Duty solеnoid A (пипец соленоиду А) 12 - Duty solеnoid B (пипец соленоиду В, мой случай, точно не помню, но около 3 т.р. вместе с работой) 13 - Shift solеnoid 3 (тут вроде не полный пипец, но близится) 14 - Shift solеnoid 2 (аналогично) 15 - Shift solеnoid 1 (аналогично) 21 - ATF temp sеnsor (Датчик температуры ATF ёк) 22 - Atmospheric sеnsor (Это собственно и есть МАФ) 23 - Еngine revolutiоn signal (ХЗ, может датчик детонации) 24 - Duty solеnoid C (любый всеми субароводами соленоид С, отвечающий за задний привод - ёк) 25 - Еngine torque control signal (датчик оборотов двигателя) 31 - Throttle sеnsor (датчик положения дроссельной заслонки) 32 - Vehicle speed sеnsor 1 (датчик скорости) 33 - Vehicle speed sеnsor 2 (датчик скорости) 75 АКПП Некорректная последовательность переключения. Требуется диагностика АКПП. 79 АКПП Перегрев АКПП, необходима диагностика АКПП. 81 АКПП Некорректное напряжение в цепи соленоида переключения 2-3; необходима диагностика АКПП. 82 АКПП Некорректное напряжение в цепи соленоида переключения 1-2; необходима диагностика АКПП. 83 АКПП Цепь соленоида ТСС - высокое напряжение на соленоиде при активации; необходима диагностика АКПП. 84 АКПП Некорректное напряжение в цепи соленоида переключения 3-2; необходима диагностика АКПП. 85 АКПП Заклинивание соленоида TCC - необходима диагностика АКПП. 90 АКПП Некорректное напряжение в цепи соленоида ТСС; необходима диагностика АКПП.
Последна промяна BAlexandrov на Чет Дек 10, 2009 8:37 pm, променена общо 1 път
| Чет Дек 10, 2009 8:35 pm |
BAlexandrov
Erasing trouble codes Engine at normal operating temperature. Ensure ignition switched OFF. Select neutral (MT). Select 'P' (AT). Connect engine diagnostic link connectors (green and black) Fig. 1 [1] & [2]. Switch ignition ON. DO NOT start engine. Check that MIL illuminates. Select 'N' (AT). Select 'P' (AT). Start engine. Drive vehicle for 1 minute minimum at 7 mph minimum. Increase engine speed to 2000 rpm for 1 minute minimum. Check that MIL flashes: Code 11111. No fault found. Switch ignition OFF. Disconnect engine diagnostic link connectors (black and green) Fig. 1 [1] & [2].
| Чет Дек 10, 2009 8:36 pm |
BAlexandrov
These are the pinouts of the diagnostic connectors in the drivers kick panel
B34 Manufacturing check connector pinout (black) 1 ABS 2 ABS 3 ABS 4 ABS 5 Cruise = B35-4 6 TCU 7 Steering = B36-7 [PAS Diagnostic] 8 ??? not connected on my car 9 Airbag 10 ABS/TCU 11 ABS 12 ABS 13 Receive Data (ECU/TCU/Cruise) = B35-3 14 Transmit Data (ECU/TCU/Cruise) = B35-2 15 ??? Possibly +12v 16 Ground 17 ECU = B36-1 [ECU Test Mode] 18 Steering = B36-5 [PAS Test Mode] 19 ??? not connected on my car 20 Airbag = B36-3 [SRS Clear Memory]
B35 select monitor connector pinout (yellow) 1 ??? not connected on my car 2 Transmit Data (ECU/TCU/Cruise) = B34-14 3 Receive Data (ECU/TCU/Cruise) = B34-13 4 Cruise = B34-5 5 +12v 6 ??? not connected on my car 7 ??? not connected on my car 8 ECU 9 Ground
B36 diagnostic connector pinout (black) 1 ECU = B34-17 [ECU Test Mode] 2 ECU [ECU Read Memory] 3 Airbag = B34-20 [SRS Clear Memory] 4 4WS [4WS Read Memory] 5 Steering = B34-18 [PAS Test Mode] 6 Steering [PAS Read Memory] 7 Steering = B34-7 [PAS Diagnostic] 8 Seatbelt [Belt Diagnostic] 9 Airbag [SRS Diagnostic]] 10 Ground
| Чет Дек 10, 2009 8:39 pm |
agogov
| Чет Дек 10, 2009 8:44 pm |
Потребители разглеждащи този форум: 0 регистрирани и 26 госта |
