 Симптоми и диагноза на бензинов двигател
Постове: 1880
Автомобил: Forester 2.0
или 39 причини и решения на проблеми за атмосферен и турбо мотор.
или два листа хартия в жабката против уроки. Откакто съм ги сложил при кабела- нищо не се обажда. :smt129
Систематизирал съм ги по азбучен ред (горе-долу) за по-лесно търсене, мислих да ги извадя по симптоми, но е хубаво да се четат подред за обща култура.
CRANKSHAFT POSITION SENSOR “A” CIRCUIT
TROUBLE SYMPTOM:
• Engine stalls.
• Failure of engine to start
CAMSHAFT POSITION-TIMING OVER-ADVANCED OR SYSTEM PERFORMANCE
TROUBLE SYMPTOM:
• Engine stalls.
• Erroneous idling
CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD
TROUBLE SYMPTOM:
• Engine stalls.
• Idle mixture is out of specifications.
CONTROL MODULE PERFORMANCE
TROUBLE SYMPTOM:
• Erroneous idling
• Poor driving performance
COOLANT THERMOSTAT (COOLANT TEMPERATURE BELOW
THERMOSTAT REGULATING TEMPERATURE)
TROUBLE SYMPTOM:
Thermostat remains open.
CYLINDER 4 MISFIRE DETECTED
TROUBLE SYMPTOM:
• Engine stalls.
• Erroneous idling
• Rough driving
EXHAUST GAS TEMPERATURE SENSOR CIRCUIT LOW
TROUBLE SYMPTOM:
• Hard to start
• Erroneous idling
EXHAUST GAS TEMPERATURE TOO HIGH
TROUBLE SYMPTOM:
• Erroneous idling
ENGINE COOLANT TEMPERATURE CIRCUIT LOW INPUT
TROUBLE SYMPTOM:
• Hard to start
• Erroneous idling
EVAPORATIVE EMISSION CONTROL SYSTEM LEAK DETECTED
(SMALL LEAK)
TROUBLE SYMPTOM:
• Fuel odor
• There is a hole of more than 1.0 mm (0.04 in) dia. in evaporation system or fuel tank.
(VERY SMALL LEAK)
TROUBLE SYMPTOM:
• Fuel odor
• There is a hole of more than 0.5 mm (0.020 in) dia. in evaporation system or fuel tank.
(FUEL CAP LOOSE/OFF)
TROUBLE SYMPTOM:
• Fuel odor
• Fuel filler cap is loose or not installed.
EVAPORATIVE EMISSION CONTROL SYSTEM PURGE CONTROL
VALVE CIRCUIT LOW
TROUBLE SYMPTOM:
Erroneous idling
EVAPORATIVE EMISSION CONTROL SYSTEM PURGE CONTROL VALVE
TROUBLE SYMPTOM:
Erroneous idling
INTAKE AIR TEMPERATURE CIRCUIT RANGE/PERFORMANCE
TROUBLE SYMPTOM:
• Erroneous idling
IDLE CONTROL SYSTEM RPM LOWER THAN EXPECTED
TROUBLE SYMPTOM:
• Engine is difficult to start.
• Engine does not start.
• Erroneous idling
• Engine stalls.
IDLE CONTROL SYSTEM RPM HIGHER THAN EXPECTED
TROUBLE SYMPTOM:
Engine keeps running at higher revolution than specified idling revolution.
IDLE CONTROL SYSTEM MALFUNCTION (FAIL-SAFE)
TROUBLE SYMPTOM:
• Engine keeps running at higher revolution than specified idling revolution.
• Fuel is cut according to fail-safe function.
INTERNAL CONTROL MODULE RANDOM ACCESS MEMORY
(RAM) ERROR
TROUBLE SYMPTOM:
• Engine stalls.
INSUFFICIENT COOLANT TEMPERATURE FOR CLOSED
LOOP FUEL CONTROL
TROUBLE SYMPTOM:
Engine will not return to idling.
KNOCK SENSOR 1 CIRCUIT LOW INPUT
TROUBLE SYMPTOM:
• Knocking occurs.
MANIFOLD ABSOLUTE PRESSURE/BAROMETRIC PRESSURE
TROUBLE SYMPTOM:
MISFIRE DETECTED (HIGH TEMPERATURE EXHAUST GAS)
• Erroneous idling
• Engine stalls.
MASS OR VOLUME AIR FLOW CIRCUIT RANGE/PERFORMANCE
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
NEUTRAL SWITCH INPUT CIRCUIT LOW
TROUBLE SYMPTOM:
Erroneous idling
NEUTRAL SWITCH INPUT CIRCUIT HIGH
TROUBLE SYMPTOM:
Erroneous idling
OCV SOLENOID VALVE SIGNAL A CIRCUIT OPEN
TROUBLE SYMPTOM:
Erroneous idling
OCV SOLENOID VALVE SIGNAL A CIRCUIT SHORT
TROUBLE SYMPTOM:
Erroneous idling
POSITIVE CRANKCASE VENTILATION (BLOW-BY) FUNCTION PROBLEM
TROUBLE SYMPTOM:
Erroneous idling
SYSTEM TOO RICH
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
STARTER REQUEST CIRCUIT
TROUBLE SYMPTOM:
STARTER SWITCH CIRCUIT LOW INPUT
TROUBLE SYMPTOM:
THROTTLE/PEDAL POSITION SENSOR/SWITCH
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
TURBO/SUPER CHARGER WASTEGATE SOLENOID “A” RANGE/PERFORMANCE
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
TUMBLE GENERATED VALVE POSITION SENSOR 2 CIRCUIT LOW
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
TUMBLE GENERATED VALVE POSITION SENSOR 2 CIRCUIT HIGH
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
THROTTLE ACTUATOR CONTROL MOTOR CIRCUIT RANGE/PERFORMANCE
TROUBLE SYMPTOM:
• Erroneous idling
• Engine stalls.
TROUBLE SYMPTOM:
• Erroneous idling
VENT CONTROL SOLENOID VALVE FUNCTION PROBLEM
TROUBLE SYMPTOM:
Improper fuel supply
Еnjoy! :smt033
Сря Окт 05, 2011 11:10 am
Потребители разглеждащи този форум: 0 регистрирани и 74 госта
