 Custom 100mm. TMIC за WRX ver.3-6
Постове: 484
http://www.ebay.co.uk/itm/Fit-Subaru-Im ... 1377058712
Продавам употребяван кулер,като този от линка горе. Кулера е със сто милиметрова пита,и е за директен монтаж.
Продава се без Y-pipe.
Цена:99лв.
Намира се в София.
Контакт: О88ббз17о1
Ето му и характеристиките:
Type
Top Mount Intercooler(Tube and Fin , by vacuum braze) , 100mm Thickness !!
Material
100% Aluminum , Vacuum Brased
Application
Subaru GC8 Type D-G
1996-2000
EJ20
Core Size
380x160x100mm 15”x3.25”x4”
Overall size
470x300x120mm 18.5”x12”x4.75”, Stock Outlet Size : 70mm ( 2.75 inch )
Weight
Only 4.8kg
Description
100% Direct Bolt-on
No Major Modification need
Intercooler Thickness is 100mm, it is 2 times air flow volume than stock Top Mount Intercooler. Instant power upgraded !!!
Small Modification :
1. The Top mount intercooler is 100mm thick, you have to cut the Rubber seal in the bonnet , the rubber seal is to vent the air to stock intercooler for cooling Now the IC is thicker so the rubber part is no need in order to close your bonnet properly.
2. For the fitment, Due to some WRX the mounting position is different. We have included a small mounting so you can connect the right side mounting to your car.
3. For the Y-pipe, Due to some STI / WRX cars , the flange is little wider , the Y-pipe Flange Hole has to drill a little larger ( 0.5mm ) for perfect fitment.
029636928.jpg [ 95.88 KiB | Прегледано 710 пъти ]
029636931.jpg [ 91.28 KiB | Прегледано 710 пъти ]
P5050008.JPG [ 29.76 KiB | Прегледано 710 пъти ]
17ac6bb3f21f323d63295887fee87233_arc-100-size.jpg [ 86.91 KiB | Прегледано 710 пъти ]
Съб Яну 09, 2016 7:01 am
Постове: 484
За архива....
Сря Яну 20, 2016 6:09 pm
Потребители разглеждащи този форум: 0 регистрирани и 55 госта
