 Как се сменя маслото на кормилната уредба (хидравликата)
Регистриран на: Нед Авг 11, 2013 10:34 am
Постове: 4
Автомобил: forester98
Здравейте !!
Нека който знае да сподели от къде се източва маслото /power steering/за смяна
и на какъв интервал го правите?
фори2.0 98г-автоматик
благодаря
Нед Авг 11, 2013 11:08 am
Постове: 4
до тук намерих това:
-Jack up the car
-Open fill cap
-Get under car
-Place a pan to catch the fluid under the steering rack lines
-Disconnect hard line from steering rack
-Turn on the car
-Turn the wheel left to right a few times to let the power steering pump out the old fluid
-Turn off the motor
-Turn the steering wheel back and forth from lock to lock until all old fluid is done leaking out
-Reconnect steering fluid line
-Fill new fluid
-Turn on the car
-Turn the steering wheel to get the steering pump to suck some of the fluid down
-Continue filling until all air bubbles are out of the line
-Fill to the correct fill line and close the filler cap
-Turn off car
-Remove catch pan from under the car
-Lower car from jackstands
-Done
и това
http://www.subaruforester.org/vbulletin ... sh-110630/
Нед Авг 11, 2013 1:22 pm
