Отговори на тема стр <  1, 2
 2 дин за В12
Регистриран на: Пон Мар 18, 2013 3:16 pm
Постове: 10
Местоположение: sofia
Автомобил: Subaru Outback H6 2001
Телефон: 0887502588
GX-608EF2
36
SPECIFICATIONS
KENWOOD follows a policy of continuous advancements in development. For this reason specifications may be changed without notice.
KENWOOD ELECTRONICS ITALIA S.p.A.
Via G. Sirtori 7/9, 20129 Milano, Italy
KENWOOD IBÉRICA S.A.
Bolivia, 239-08020 Barcelona, Spain
KENWOOD ELECTRONICS AUSTRALIA PTY. LTD.
(A.C.N. 001 499 074)
16 Giffnock Avenue, North Ryde, N.S.W. 2113, Australia
KENWOOD ELECTRONICS (HONG KONG) LTD.
Unit 3712-3724, Level 37, Tower 1, Metroplaza,
223 Hing Fong Road, Kwai Fong, N.T., Hong Kong
KENWOOD ELECTRONICS GULF FZE
P.O. Box 61318, Jebel Ali, Dubai, U.A.E.
KENWOOD ELECTRONICS (THAILAND) CO., LTD.
2019 New Pechburi Road, Bangkapi, Huaykwang,
Bangkok, 10320 Thailand
KENWOOD ELECTRONICS SINGAPORE PTE. LTD.
1 Genting Lane, #07-00, Kenwood Building, Singapore 349544
KENWOOD ELECTRONICS (MALAYSIA) SDN BHD
#4.01 Level 4, Wisma Academy Lot 4A, Jalan 19/1,
46300 Petaling Jaya, Selangor Darul Ehsan, Malaysia
KENWOOD CORPORATION
14-6, Dogenzaka 1-chome, Shibuya-ku, Tokyo 150-8501, Japan
KENWOOD SERVICE CORPORATION
P.O. Box 22745, 2201 East Dominguez Street,
Long Beach, CA90801-5745, U.S.A.
KENWOOD ELECTRONICS CANADA INC.
6070 Kestrel Road, Mississauga, Ontario, Canada L5T 1S8
KENWOOD ELECTRONICS LATIN AMERICA S.A.
P.O. Box 55-2791, Piso 6, Plaza Chase, Cl. 47 y,
Aquilino de la Guardia, Panama, Republic of Panama
KENWOOD ELECTRONICS BRASIL LTDA.
Av. Moema, 170-17°, Andar-Cobertura “B”,
Ed. Maximum Service Center, 04077-020 Moema,
São Paulo-SP-Brasil
KENWOOD ELECTRONICS UK LIMITED
Kenwood House, Dwight Road, Watford, Herts,
WD1 8EB United Kingdom
KENWOOD ELECTRONICS DEUTSCHLAND GMBH
Rembrücker-Str. 15, 63150 Heusenstamm, Germany
KENWOOD ELECTRONICS FRANCE S.A.
13, Boulevard Ney, 75018 Paris, France
KENWOOD ELECTRONICS BELGIUM N.V.
Mechelsesteenweg 418, B-1930 Zaventem, Belgium
FM Section
Frequency Range .............................. 87.5MHz~108.0MHz
(Frequency Step) (50kHz)
Usable Sensitivity(S/N:26dB) ........... 0.7mV/75W
Quieting Sensitivity(S/N:50dB) ......... 1.6mV/75W
Frequency Response(±3.0dB) ........... 30Hz~15kHz
S/N(dB) ..............................................65dB(MONO)
Selectivity ........................................... ³80dB(±400kHz)
Stereo Separation ............................. 35dB(1kHz)
MW Section
Frequency Range .............................. 531kHz~1611kHz
(Frequency Step) (9kHz)
Usable Sensitivity(S/N:20dB) ........... 25mV
LW Section
Frequency Range .............................. 153kHz~281kHz
Usable Sensitivity(S/N:20dB) ........... 45mV
CASSETTE Section
Tape Speed ....................................... 4.76cm/sec.
Wow & Flutter ................................... 0.08(%)(WRMS)
Frequency Response(±3.0dB) .......... 25~22kHz(70ms)
Stereo Separation ............................. 40(1kHz)
S/N Ratio(dB)
Dolby NR off .............................. 60dB(BNR off)
Dolby BNR on ............................ 68dB
CD Section
Laser Diode........................................ GaAIAs(l=780nm)
Digital Filter(D/A) ............................... 8 Times Over Sampling
D/A Converter.................................... 1Bit
Spindle Speed................................... 500~200rpm(CLV)
Wow & Flutter ..................................... Below Measurable Limit
Frequency Response(±1dB) .............. 10Hz~20kHz
Total Harmonic Distortion ................... 0.01%(1kHz)
S/N Ratio............................................ 93dB(1kHz)
Dynamic Range .................................. 93dB
Channel Separation ........................... 85dB
AMPLIFIER Section
Maximum Power ................................35W´4
PWR...................................................21W´4(1kHz 10%THD)
General
Operating Voltage ............................. 13.2V(10.8V~15.6V)
Current Consumption ........................ 10A
Installation Size (W) ........................... 178(mm) 7(inch)
(H) ........................... 100(mm) 3-15/18(inch)
(D) ........................... 169(mm) 6-5/8(inch)
Weight ................................................ 2.55kg
Съб Дек 19, 2015 12:29 pm
Регистриран на: Вто Ное 27, 2012 11:46 am
Постове: 17
Автомобил: Subaru Outback B12 H6
Мдаааа...шантава работа! Мишо,, пич голям ама налагаме китайчето по таблото и стърчи настрани. Тоест китайчето си е по спецификация 178мм. 2дина на бека измерен отвън по таблото е 175мм.!? А сега де..? В същото време колегата Захов сподели, че неговото също е на 178мм. а е станало. Обърках се доста #-o
А да, Мишо вика слагал съм на такава кола ама Пайнер...хубаво де ама гледам Пайнерите и те са на 178мм.
Съб Дек 19, 2015 12:54 pm
Постове: 2115
Да слагал е моя пайнер на легасито, но без лайсната да не би с нея да е толкова.
Съб Дек 19, 2015 2:08 pm
Постове: 17
Не бе колега, явно китайчето си е по стандарта за 2дин. Не схващам, защо на бека е на 175мм. външно. Не сме разглабяли колата, ама не вярвам да се разшири като го свалим.. незнам ](*,)
Съб Дек 19, 2015 2:31 pm
Постове: 216
Колега, не прави сметките за монтажа без да си махнал таблото.
Слизах специално да си меря таблото и действително ширината на дупката в пластмасовата част на таблото е 175мм (да не кажа дори милиметър-два по-малко..)
Pioneer-a както и заводския kenwood както колегата е посочил по-горе са дадени на 178мм обаче ако погледнеш и при двата дека, лицивият панел е няколко милиметъра по-малък от всички страни
Реално ако лицивият панел при мен беше както задната част на 178мм, тогава нямаше да пасне.
При китайчето също има леко ръбче и панелът ми се струва е малко по-тесен от останалата част
Логиката при монтажа е , че се маха пластмасовата конзола, инсталира се дека и после отгоре се слага пластмасата, на която реално и трябва точно тези няколко милимитъра по къс панел, за да легне върху него.
Демек, ако аз бях тръгнал да монтирам pioneer-a без да махна таблото първо, със сигурност нямаше да мине през отвора на пластмасата...
Така, че вътре в самото табло монтажно място за 178мм със сигурност имаш. Ако все пак дори най-предната част на панела ти е 178, защо просто не го монтираш няколко милиметра по-навътре и като монтираш обратно таблото, най-много да изглежда малко по-вдлъбнато..
Ако още не си намерил решение след нова година може да се разберем да го погледнем заедно :good:
 9
Съб Дек 19, 2015 6:47 pm
Регистриран на: Сря Авг 12, 2015 3:48 pm
Постове: 61
Skype: jastaprasta00
Автомобил: Subaru Outbаck 2016 2,5 at
Телефон: 0899293643
И при мен е така,лицевият панел е 172мм,а тялото 178мм,затова му казах на колегата че може да играе с дълбочина,или напред или назад.Така са направени да могат да се отварят екраните,и да няма нужда от допълнителни лайсни,както при 1 дин устройствата.
Нед Дек 20, 2015 11:45 am
Регистриран на: Сря Юли 25, 2012 9:49 pm
Постове: 51
Автомобил: Outback H6 Silver Esprit
Телефон: 0898313050
http://m.aliexpress.com/item/3246028966 ... sitedetail
Пон Дек 21, 2015 10:20 pm
Постове: 51
Телефон: 0898313050
Някой може ли да каже това струва ли си? Нищо не разбирам от тези неща. Но ми се струва евтино. Дали е боклук?
Пон Дек 21, 2015 10:22 pm
Постове: 17
Мдаааа...пак се връщам от Мишо и пак нъцки!! След разглабяне на таблото става ясно, че просто не влиза лицевия панел на китайчето в отвора на лайсната на бека. Тоест китайчето и по размер на панела е 178мм. Най-тъпото, е че и двете тъпи копчета (врътките) във външна част са на отстояние 178мм., което не позволява и по-дълбоко монтиране. Ако се реже лайсната моооже и да стане, но това е варварство за мен и не е вариянт.
Така, че другари ако ви скимне тази дивотия и за да не ](*,) Е ЗАДЪЛЖИТЕЛНО широчината на преден панел на 2 дин устройство за бек В12 да е макс 172мм.
Вто Дек 22, 2015 11:23 am
Постове: 216
жалко..значи накрая се оказа най-тъпия сценарий, щом и врътките пречат :-~
Вариант е да намериш пластамсовата конзола от морга и да си я изрежеш на спокойствие като си къташ оригиналната или да се впуснеш в нова покупко-продажба..
Успех!
Вто Дек 22, 2015 12:03 pm
Постове: 956
Автомобил: Subaru Outback, MT
ludopile написа:
Колко е дебела тази лайсна? Има вариант да се разшири на лазер или рутер, стига да е удобно да се хване към машините. На ръка едва ли ще се получи добре.
Вто Дек 22, 2015 1:24 pm
Постове: 216
12 мм. е. аз си го представях евентуално да се "бъз"-не с абразивно борче от двете страни
Вто Дек 22, 2015 2:07 pm
Постове: 216
1-2мм
Вто Дек 22, 2015 2:08 pm
Постове: 956
bozzerreaneux написа:
1-2мм
Значи, ще е по-бързо на лазер. Нека колегата ludopile да потърси фирма, която се занимава с реклама и има малък лазер за пластмаси. Не би трябвало да ти вземат повече от 5-10лв. Според мен и 5лв са много, но все пак.
Вто Дек 22, 2015 2:30 pm
Постове: 61
Телефон: 0899293643
sinsist написа:
Колега не си вкарвай гол с тези неща,още повече че ще има и мито ми се струва.По добре си намери нещо хубаво,макар и втора ръка,за тези пари които ще дадеш за това новото,ми се струва че ще си намериш марково употребявано,ако искаш 2 дин музика,или ново китайско от тук,поне ще има гаранция,разгледай сайтовете има за по 300-350 лв нови.
Вто Дек 22, 2015 7:00 pm
Постове: 51
Телефон: 0898313050
На мен ми е най вече заради навигацията. Но прав си,нещо не ми вдъхва доверие. Пък и както чета по горе,май не става за В12....
Вто Дек 22, 2015 10:22 pm
Постове: 111
Автомобил: XV 2.0D, H6 2002, LPG
Колега, успя ли да монтираш 2 дин устройството?
И аз се запътих да си купувам 2 дин устройсво,
обаче сега измерих размера на оригиналното радио и той е 170мм,
а на стандартно радио е 178мм./ширина/.
Дали изобщо ще може да се сложи и 1дин радио?
Така излиза, че не можем да си купим и едно обикновено радио-CD...
Чет Юли 21, 2016 10:50 am
Постове: 160
nikpl написа:
Ако беше прочел темата, нямаше да ти останат въпроси за задаване ;)
Чет Юли 21, 2016 12:30 pm
Постове: 111
Четох, четох, имах и въпроси ама ги реших сам, ето резултата
Photo0007a.jpg [ 116.18 KiB | Прегледано 511 пъти ]
Нед Авг 07, 2016 9:01 pm
Постове: 2115
Според мен всеки стандартен и Некитайски 2 DIN ще влезе като удома си , имам пред Кенуд , Пионер, Босе и тн, правен по-бели стандарти
Освен сегашния ми пионер съм мерил и кенуд , също жми града циганите краднат, но за китайците явно излишъка на материал не е проблем ;) .
Не че горните марки на са правени пак там , но поне спазват размерите явно.
Пон Авг 08, 2016 7:22 am
Потребители разглеждащи този форум: mirkostov, slavckc и 70 госта
