Страница 2 от 2
стр < 1, 2 |
julien 55
Регистриран на: Пон Мар 18, 2013 3:16 pm Постове: 10 Местоположение: sofia
Автомобил: Subaru Outback H6 2001
Телефон: 0887502588
GX-608EF2 36 SPECIFICATIONS KENWOOD follows a policy of continuous advancements in development. For this reason specifications may be changed without notice. KENWOOD ELECTRONICS ITALIA S.p.A. Via G. Sirtori 7/9, 20129 Milano, Italy KENWOOD IBÉRICA S.A. Bolivia, 239-08020 Barcelona, Spain KENWOOD ELECTRONICS AUSTRALIA PTY. LTD. (A.C.N. 001 499 074) 16 Giffnock Avenue, North Ryde, N.S.W. 2113, Australia KENWOOD ELECTRONICS (HONG KONG) LTD. Unit 3712-3724, Level 37, Tower 1, Metroplaza, 223 Hing Fong Road, Kwai Fong, N.T., Hong Kong KENWOOD ELECTRONICS GULF FZE P.O. Box 61318, Jebel Ali, Dubai, U.A.E. KENWOOD ELECTRONICS (THAILAND) CO., LTD. 2019 New Pechburi Road, Bangkapi, Huaykwang, Bangkok, 10320 Thailand KENWOOD ELECTRONICS SINGAPORE PTE. LTD. 1 Genting Lane, #07-00, Kenwood Building, Singapore 349544 KENWOOD ELECTRONICS (MALAYSIA) SDN BHD #4.01 Level 4, Wisma Academy Lot 4A, Jalan 19/1, 46300 Petaling Jaya, Selangor Darul Ehsan, Malaysia KENWOOD CORPORATION 14-6, Dogenzaka 1-chome, Shibuya-ku, Tokyo 150-8501, Japan KENWOOD SERVICE CORPORATION P.O. Box 22745, 2201 East Dominguez Street, Long Beach, CA90801-5745, U.S.A. KENWOOD ELECTRONICS CANADA INC. 6070 Kestrel Road, Mississauga, Ontario, Canada L5T 1S8 KENWOOD ELECTRONICS LATIN AMERICA S.A. P.O. Box 55-2791, Piso 6, Plaza Chase, Cl. 47 y, Aquilino de la Guardia, Panama, Republic of Panama KENWOOD ELECTRONICS BRASIL LTDA. Av. Moema, 170-17°, Andar-Cobertura “B”, Ed. Maximum Service Center, 04077-020 Moema, São Paulo-SP-Brasil KENWOOD ELECTRONICS UK LIMITED Kenwood House, Dwight Road, Watford, Herts, WD1 8EB United Kingdom KENWOOD ELECTRONICS DEUTSCHLAND GMBH Rembrücker-Str. 15, 63150 Heusenstamm, Germany KENWOOD ELECTRONICS FRANCE S.A. 13, Boulevard Ney, 75018 Paris, France KENWOOD ELECTRONICS BELGIUM N.V. Mechelsesteenweg 418, B-1930 Zaventem, Belgium FM Section Frequency Range .............................. 87.5MHz~108.0MHz (Frequency Step) (50kHz) Usable Sensitivity(S/N:26dB) ........... 0.7mV/75W Quieting Sensitivity(S/N:50dB) ......... 1.6mV/75W Frequency Response(±3.0dB) ........... 30Hz~15kHz S/N(dB) ..............................................65dB(MONO) Selectivity ........................................... ³80dB(±400kHz) Stereo Separation ............................. 35dB(1kHz) MW Section Frequency Range .............................. 531kHz~1611kHz (Frequency Step) (9kHz) Usable Sensitivity(S/N:20dB) ........... 25mV LW Section Frequency Range .............................. 153kHz~281kHz (Frequency Step) (9kHz) Usable Sensitivity(S/N:20dB) ........... 45mV CASSETTE Section Tape Speed ....................................... 4.76cm/sec. Wow & Flutter ................................... 0.08(%)(WRMS) Frequency Response(±3.0dB) .......... 25~22kHz(70ms) Stereo Separation ............................. 40(1kHz) S/N Ratio(dB) Dolby NR off .............................. 60dB(BNR off) Dolby BNR on ............................ 68dB CD Section Laser Diode........................................ GaAIAs(l=780nm) Digital Filter(D/A) ............................... 8 Times Over Sampling D/A Converter.................................... 1Bit Spindle Speed................................... 500~200rpm(CLV) Wow & Flutter ..................................... Below Measurable Limit Frequency Response(±1dB) .............. 10Hz~20kHz Total Harmonic Distortion ................... 0.01%(1kHz) S/N Ratio............................................ 93dB(1kHz) Dynamic Range .................................. 93dB Channel Separation ........................... 85dB AMPLIFIER Section Maximum Power ................................35W´4 PWR...................................................21W´4(1kHz 10%THD) General Operating Voltage ............................. 13.2V(10.8V~15.6V) Current Consumption ........................ 10A Installation Size (W) ........................... 178(mm) 7(inch) (H) ........................... 100(mm) 3-15/18(inch) (D) ........................... 169(mm) 6-5/8(inch) Weight ................................................ 2.55kg
| Съб Дек 19, 2015 12:29 pm |
ludopile
Регистриран на: Вто Ное 27, 2012 11:46 am Постове: 17
Автомобил: Subaru Outback B12 H6
Мдаааа...шантава работа! Мишо,, пич голям ама налагаме китайчето по таблото и стърчи настрани. Тоест китайчето си е по спецификация 178мм. 2дина на бека измерен отвън по таблото е 175мм.!? А сега де..? В същото време колегата Захов сподели, че неговото също е на 178мм. а е станало. Обърках се доста  А да, Мишо вика слагал съм на такава кола ама Пайнер...хубаво де ама гледам Пайнерите и те са на 178мм.
| Съб Дек 19, 2015 12:54 pm |
quietriot
Да слагал е моя пайнер на легасито, но без лайсната да не би с нея да е толкова.
| Съб Дек 19, 2015 2:08 pm |
ludopile
Не бе колега, явно китайчето си е по стандарта за 2дин. Не схващам, защо на бека е на 175мм. външно. Не сме разглабяли колата, ама не вярвам да се разшири като го свалим.. незнам ](./images/smilies/eusa_wall.gif)
| Съб Дек 19, 2015 2:31 pm |
bozzerreaneux
Регистриран на: Сря Мар 19, 2014 8:54 pm Постове: 216
Колега, не прави сметките за монтажа без да си махнал таблото. Слизах специално да си меря таблото и действително ширината на дупката в пластмасовата част на таблото е 175мм (да не кажа дори милиметър-два по-малко..) Pioneer-a както и заводския kenwood както колегата е посочил по-горе са дадени на 178мм обаче ако погледнеш и при двата дека, лицивият панел е няколко милиметъра по-малък от всички страни   Реално ако лицивият панел при мен беше както задната част на 178мм, тогава нямаше да пасне. При китайчето също има леко ръбче и панелът ми се струва е малко по-тесен от останалата част Логиката при монтажа е , че се маха пластмасовата конзола, инсталира се дека и после отгоре се слага пластмасата, на която реално и трябва точно тези няколко милимитъра по къс панел, за да легне върху него. Демек, ако аз бях тръгнал да монтирам pioneer-a без да махна таблото първо, със сигурност нямаше да мине през отвора на пластмасата... Така, че вътре в самото табло монтажно място за 178мм със сигурност имаш. Ако все пак дори най-предната част на панела ти е 178, защо просто не го монтираш няколко милиметра по-навътре и като монтираш обратно таблото, най-много да изглежда малко по-вдлъбнато.. Ако още не си намерил решение след нова година може да се разберем да го погледнем заедно
9
| Съб Дек 19, 2015 6:47 pm |
атанас захов
Регистриран на: Сря Авг 12, 2015 3:48 pm Постове: 61 Местоположение: Варна
Skype: jastaprasta00
Автомобил: Subaru Outbаck 2016 2,5 at
Телефон: 0899293643
И при мен е така,лицевият панел е 172мм,а тялото 178мм,затова му казах на колегата че може да играе с дълбочина,или напред или назад.Така са направени да могат да се отварят екраните,и да няма нужда от допълнителни лайсни,както при 1 дин устройствата.
| Нед Дек 20, 2015 11:45 am |
sinsist
Регистриран на: Сря Юли 25, 2012 9:49 pm Постове: 51
Автомобил: Outback H6 Silver Esprit
Телефон: 0898313050
| Пон Дек 21, 2015 10:20 pm |
sinsist
Телефон: 0898313050
Някой може ли да каже това струва ли си? Нищо не разбирам от тези неща. Но ми се струва евтино. Дали е боклук?
| Пон Дек 21, 2015 10:22 pm |
ludopile
Мдаааа...пак се връщам от Мишо и пак нъцки!! След разглабяне на таблото става ясно, че просто не влиза лицевия панел на китайчето в отвора на лайсната на бека. Тоест китайчето и по размер на панела е 178мм. Най-тъпото, е че и двете тъпи копчета (врътките) във външна част са на отстояние 178мм., което не позволява и по-дълбоко монтиране. Ако се реже лайсната моооже и да стане, но това е варварство за мен и не е вариянт. Така, че другари ако ви скимне тази дивотия и за да не ](./images/smilies/eusa_wall.gif) Е ЗАДЪЛЖИТЕЛНО широчината на преден панел на 2 дин устройство за бек В12 да е макс 172мм. Поздрави
| Вто Дек 22, 2015 11:23 am |
bozzerreaneux
жалко..значи накрая се оказа най-тъпия сценарий, щом и врътките пречат Вариант е да намериш пластамсовата конзола от морга и да си я изрежеш на спокойствие като си къташ оригиналната или да се впуснеш в нова покупко-продажба.. Успех!
| Вто Дек 22, 2015 12:03 pm |
Vami
ludopile написа: лицевия панел на китайчето в отвора на лайсната на бека Колко е дебела тази лайсна? Има вариант да се разшири на лазер или рутер, стига да е удобно да се хване към машините. На ръка едва ли ще се получи добре.
| Вто Дек 22, 2015 1:24 pm |
bozzerreaneux
12 мм. е. аз си го представях евентуално да се "бъз"-не с абразивно борче от двете страни
| Вто Дек 22, 2015 2:07 pm |
bozzerreaneux
| Вто Дек 22, 2015 2:08 pm |
Vami
bozzerreaneux написа: 1-2мм Значи, ще е по-бързо на лазер. Нека колегата ludopile да потърси фирма, която се занимава с реклама и има малък лазер за пластмаси. Не би трябвало да ти вземат повече от 5-10лв. Според мен и 5лв са много, но все пак.
| Вто Дек 22, 2015 2:30 pm |
атанас захов
Телефон: 0899293643
sinsist написа: Някой може ли да каже това струва ли си? Нищо не разбирам от тези неща. Но ми се струва евтино. Дали е боклук? Колега не си вкарвай гол с тези неща,още повече че ще има и мито ми се струва.По добре си намери нещо хубаво,макар и втора ръка,за тези пари които ще дадеш за това новото,ми се струва че ще си намериш марково употребявано,ако искаш 2 дин музика,или ново китайско от тук,поне ще има гаранция,разгледай сайтовете има за по 300-350 лв нови.
| Вто Дек 22, 2015 7:00 pm |
sinsist
Телефон: 0898313050
На мен ми е най вече заради навигацията. Но прав си,нещо не ми вдъхва доверие. Пък и както чета по горе,май не става за В12....
| Вто Дек 22, 2015 10:22 pm |
nikpl
Регистриран на: Пон Окт 19, 2015 11:15 am Постове: 111 Местоположение: София
Автомобил: XV 2.0D, H6 2002, LPG
Колега, успя ли да монтираш 2 дин устройството? И аз се запътих да си купувам 2 дин устройсво, обаче сега измерих размера на оригиналното радио и той е 170мм, а на стандартно радио е 178мм./ширина/. Дали изобщо ще може да се сложи и 1дин радио? Така излиза, че не можем да си купим и едно обикновено радио-CD...
| Чет Юли 21, 2016 10:50 am |
Петър Велков
nikpl написа: Колега, успя ли да монтираш 2 дин устройството? И аз се запътих да си купувам 2 дин устройсво, обаче сега измерих размера на оригиналното радио и той е 170мм, а на стандартно радио е 178мм./ширина/. Дали изобщо ще може да се сложи и 1дин радио? Така излиза, че не можем да си купим и едно обикновено радио-CD... Ако беше прочел темата, нямаше да ти останат въпроси за задаване
| Чет Юли 21, 2016 12:30 pm |
nikpl
Четох, четох, имах и въпроси ама ги реших сам, ето резултата Прикачени файлове:
Photo0007a.jpg [ 116.18 KiB | Прегледано 492 пъти ]
| Нед Авг 07, 2016 9:01 pm |
quietriot
Според мен всеки стандартен и Некитайски 2 DIN ще влезе като удома си , имам пред Кенуд , Пионер, Босе и тн, правен по-бели стандарти Освен сегашния ми пионер съм мерил и кенуд , също жми града циганите краднат, но за китайците явно излишъка на материал не е проблем  . Не че горните марки на са правени пак там , но поне спазват размерите явно.
| Пон Авг 08, 2016 7:22 am |
Страница 2 от 2
стр < 1, 2 |
Потребители разглеждащи този форум: 0 регистрирани и 15 госта |
