Някой използвал ли е този почистващ препарат за чистене на горивна камера и дюзи от въглеродни отлагания, гума, смоли. Препоръчват да се използва на всеки 12,500km
"Engine power output is created by the burning of fuel in a vehicle's cylinders. As petrol is a hydrocarbon fuel, made up of hydrogen and carbon, after combustion it leaves carbon as a by-product or deposit. Over a relatively short period of time the carbon deposits on the walls of the combustion chamber, the piston crown (top surface), and on the valves, can result in the deterioration of engine efficiency. This may lead to poor fuel economy, reduced power and harder starting. To overcome this situation, the factory has formulated ‘Upper Engine Cleaner (SA459)’, which is a concentrated combustion chamber and induction system cleaner. This product helps clean and purge gum, varnish, and carbon deposits. Using this solvent during scheduled servicing has proven to be a valuable form of preventative maintenance.
If your vehicle were subjected to regular stop/start driving, short trips, or poor fuel quality, the build up of gum, varnish, and carbon deposits would be far more rapid. In addition to ‘Upper Engine Cleaner (SA459)’, we suggest the use of ‘SA718 Fuel Additive’ to maximise your engine’s protection against such concerns."
Both products have been specially formulated by Fuji Heavy Industries, the manufacturer of your Subaru vehicle, to be compatible with the Subaru horizontally opposed engine and it’s technically advanced electronics. These products are available through all authorised Subaru Dealers. "
enginecleaner.jpg [ 61.46 KiB | Прегледано 839 пъти ]
Пон Мар 21, 2011 5:02 pm
alex5428
Автомобил: STI (GVB)
Ами аз мисля съм го виждал на живо миналото лято в сл бряг собственика на авто мивка луксор караше едно бяро ферари и излизаики от паркинга на глобус изряза звяра и пушеше точно като на клипа.Аз бях толкова учуден,че тръгнах след него с бека мислех е събрал мотора след една две преки,да ама не нямаше го и после често го виждах с колата и се чудех как така нищо и няма после като гледах клиповете за тая пяна и навързах нещата
_________________ "ladies and gentlemen the wing is back "
Това е някаква нова измишльотина, нищо чудно да е само за щатите... не знам всъщност, но мислех да тествам BG44 http://www.bgprod.com/products/fuelair.html поне за него има много отзиви, че бива.
Пон Мар 21, 2011 6:52 pm
Yco
Автомобил: Forester 2.0
Тая "нова измишльотина" е въведена от Subaru през 2005 година и има доста потребители от Субару-форумите, ама честно и аз и нямам доверие все още, затуй питам
