2. 3.0 L MODEL SA07683A2002
1) Disconnect battery cables and then remove
battery and battery carrier.
2) Remove washer tank and put it aside.
3) Remove air cleaner lower case.
4) Disconnect connector from ignition coil.
5) Remove ignition coil.
B2M4336
6) Remove spark plug with a spark plug socket.
B2M4333
7) Set new spark plug.
Recommended spark plug:
NGK PLFR 6A-11
8) Tighten spark plug lightly with hand, and then
secure with a plug-wrench to the specified torque.
Tightening torque:
21 N·m (0.21 kgf-m, 1.5 ft-lb)
9) Tighten ignition coil.
Tightening torque:
16 N·m (0.16 kgf-m, 1.2 ft-lb)
NOTE:
Be sure to place the gasket between the cylinder
head and spark plug.
If torque wrench is not available, tighten spark
plug until gasket contacts cylinder head: then
tighten further 1/4 to 1/2 turn.
Съдейки по това описание за смяна на свещи, което набарах излиза, че има бобина на всяка свещ и няма традиционни кабели.
Интересно, защо тогава от АутоПлюс ми предлагаха кабели на някаква ужасяваща цена?!
