Четене на грешки без апаратура на Субару Аутбек 2005-2009
patko
Ровейки из интернет попаднах на това: http://www.subaruoutback.org/forums/99- ... -dtcs.htmlЗа моя изненада работи. Ето две снимки: На първата е таблото преди процедурата, а на втората - след. Според написаното в горната препратка - нямам записани грешки.
DSCF7933.JPG [ 623.76 KiB | Прегледано 6296 пъти ]
DSCF7934.JPG [ 596.87 KiB | Прегледано 6296 пъти ]
34
| Вто Окт 07, 2014 10:24 am |
BAlexandrov
Нека някой, който го е правил да го преведе/опише и да го сложим в справочника...
| Сря Окт 08, 2014 9:35 pm |
patko
ОК. Днес съм свободен и ще го преведа.
| Чет Окт 09, 2014 8:17 am |
patko
How to Read Diagnostic Trouble Codes on 2005 thru 2009 Subaru Legacy and Outback
The 2005 thru 2009 model year Legacy and Outback can display Diagnostic Trouble Codes (DTCs) directly on the dashboard. No scan tool is needed. No jumper wires are required, and it is not necessary to count blinky lights. The codes are displayed in plain text on the instrument cluster.
Trouble codes from the ECM (Engine Control Module), TCM (Transmission Control Module) and ABSCM/VDCCM (ABS or VDC Control Module) are displayed.
This procedure was distilled from the FSM. The English translation in the FSM is not very good, so I have attempted to make it easier to follow. The FSM has this procedure in the Body Section, Instrument/Driver Information, Comination Meter System chapter.
Some notes before starting:
- I believe this procedure will work for all 2005 to 2009 Legacys and Outbacks. However, I have only tested the procedure on my car, a 2007 Outback 2.5i automatic.
- I don't know of a way to reset the codes without a scan tool. Disconnecting the battery may or may not work.
- Exactly what you will see depends on what type of display your car has. There are two images of tables below, one for the Normal display and one for the Multi-Information Display that is found on Turbo models.
The Procedure
Starting condition: key off, headlight switch off.
Steps 1 through 7 must be performed within 10 seconds.
1. Turn key to ON position. This is the normal running position, the click just before starting, when all the lights on the dash come on, but before you twist to START. Don't start the engine!
2. Within 3 seconds, turn the headlight switch ON.
3. Press the Trip/Odometer button 4 times.
4. Turn the headlight switch OFF.
5. Press the Trip/Odometer button 4 times.
6. Turn headlight swtich ON.
7. Press Trip/Odometer button 4 times. At this point, the DTC display will begin.
8. Turn headlight switch OFF. Not necessary for the procedure, but your display may be dimmed and hard to read in bright sunlight. Besides, why drain the battery?
The DTCs for each module will display in order: ECM, TCM, ABSCM/VDCCM. Press the Trip/Odometer button to cycle between modules. The FSM states that the display will cycle between modules automatically every three seconds if the button is not pushed, but that did not happen in my car - I had to push the button to cycle the display.
For each module, there are three display states: - Receiving DTC from module (blinking "P" or "C") - DTC detected & displayed ("P" or "C" followed by 4 digits) - No DTC found ("P" or "C" followed by "----")
If there is a CAN (Controller Area Network) bus communication error, you will see only "----" in the display. Basically, that means that the network in your car is broken. That will need to be repaired before anything else can be done.
See the table below that applies to your car, depending on which type of display you have.
Notes
- TCM error codes will not be displayed for cars with manual transmissions. The TCM display state will remain in "Receiving DTC" (blinking "P" on display). In my case, my car is an automatic, but the blinking "P" remained, possibly because I have no codes set.
- To cancel the DTC display, turn the key to OFF.
- If the engine is started, the DTC display will remain until the car starts to move. (I did not test this)
- Past DTCs that have been repaired will be displayed until the engine is started 3 times. (I did not test this)
Преводът е едно към едно. Всичко е в първо лице единствено число от името на автора.
Как да четем кодовете за грешки на Субару Легаси и Аутбек модел 2005 до 2009. Легаси и Аутбек модел 2005 до 2009 могат да изписват кодовете за грешки директно на таблото. Не е необходим скенер. Не се свързват букси или жици. Не се броят мигащи кодове. Кодовете се показват на инструменталното табло.
Показват се кодовете за грешки от ECM (Engine Control Module), TCM (Transmission Control Module), ABS or VDC Control Module . Процедурата е от FSM. Преводът на английски език на абревиатурата FSM не е много добър, затова аз се опитах да я направя лесна за изпълнение. Процедурата се намира във FSM Body Section, Instrument/Driver Information, Comination Meter System chapter.
Някои бележки преди да започна.
- Мисля, че тази процедура ще работи на всички Легаси и Аутбек модел 2005 до 2009. Аз съм я тествал само на моята кола – Аутбек 2007 2.5 автоматик. - Не зная как да изтривам грешки без скенер. Откачането на акумулатора може да работи, но може и да не работи. - Какво ще видите точно зависи от типа на дисплея на вашата кола.Има две снимки по-надолу – едната е на нормален дисплей, а другата на мултиинформационен дисплей, който се поставя на Турбо моделите. Заб. от мен Patko - Понеже не съм регистриран в този форум, не можах да видя тези снимки.
Процедурата:
Начално състояние: Ключът на положение OFF, ключът за включване на фаровете на положение OFF. Стъпките от 1 до 7 трябва да се изпълнят в рамките на 10 секунди. 1. Завъртете ключа на положение ON. Това е нормалното работно положение на двигателя. Малко преди да стартирате, когато се появяват всички светлини по таблото, но преди да завъртите, за да стартирате двигателя. НЕ стартирайте двигателя. 2. В рамките на 3 секунди завъртете превключвателя на фаровете на положение ON. 3. Натиснете бутона Trip/Odometer 4 пъти. 4. Завъртете превключвателя на фаровете на положение OFF. 5. Натиснете бутона Trip/Odometer 4 пъти. 6. Завъртете превключвателя на фаровете на положение ON. 7. Натиснете бутона Trip/Odometer 4 пъти. В този момент ще се появят кодовете за грешки. 8. Завъртете превключвателя на фаровете на положение OFF. Това не е необходимо за процедурата, но при светнати фарове може да се затъмни дисплея и да е трудно да се види ако слънцето свети силно. Освен това защо да разреждаме акумулатора.
Кодовете за грешки ще се показват на дисплея в следния ред: ECM, TCM, ABSCM/VDCCM. Натиснете бутона Trip/Odometer, за да превключите показанията за различните модули. Във FSM е казано, че дисплеят ще превключва показанията за различните модули на всеки три секунди, но това не стана на моята кола. Трябваше да натикам бутона Trip/Odometer, за да се превключат показанията за различните модули.
За всеки модул има три състояния на дисплея. - Четене на грешки от модула – (Мигащо “P” или “С”) - Кодове за грешка – прочетени и изписани (“P” или “C” следвано от 4 цифри) - Няма кодове за грешки (“P” или “C” следвано от “----“)
Ако има грешка в комуникацията ((CAN (Controller Area Network) bus)) вие ще видите на дисплея само “----“. Това означава, че има проблем с комуникацията във вашата кола. Това трябва да се поправи преди всичко останало.
Забележки: - Грешки в трансмисията TCM модула няма да се показват, ако сте с ръчна трансмисия. Дисплеят ще остане в режим „четене на грешки от ТСМ модула ( мигащо Р на дисплея). В моят случай, (аз съм с автоматична трансмисия), но “мигащото Р на дисплея” си остана (вероятно, защото няма грешки в модула на трансмисията ТСМ). - За да прекратиш процедурата – завърташ ключа на положение OFF. - Ако двигателят се стартира, кодовете ще останат на дисплея докато колата започне да се движи (Аз не съм пробвал това). - Стари кодове, които са били ремонтирани се пазят докато двигателят се стартира три пъти.
27
| Чет Окт 09, 2014 9:57 am |
crazyking
Регистриран на: Съб Май 03, 2014 4:57 pm Постове: 8 Местоположение: London UK
Автомобил: subaru legacy 2.0R
пробвах го няколко пъти,но нещо не ми се получава...какво ще рече това за фаровете за 3 секунди. Колата е Легаси 2005 2.0R
| Чет Окт 23, 2014 2:27 pm |
patko
Всички действия - от 1 до 7 трябва да се изпълнят за 10 сек, а единичното - фаровете, следвано от бутона - в рамките на 3 сек.
| Чет Окт 23, 2014 4:25 pm |
crazyking
успях  честито на мен 3 грешки ](./images/smilies/eusa_wall.gif)
| Пет Окт 24, 2014 6:55 pm |
pachov85
Регистриран на: Чет Апр 07, 2016 4:00 am Постове: 11
Автомобил: subaru outback 2.5 2005
Телефон: TTHJTT
Пробвах но на мен ми изписва само s On и като задържа бутона става s Off. subaru outback 2005 2.5 ръцна
| Съб Мар 17, 2018 7:14 am |
slavckc
Регистриран на: Съб Апр 05, 2014 3:34 pm Постове: 176 Местоположение: Варна
Skype: slav_ckc
Телефон: 08889566нулашест
И на Форестър 2009 г. стана. Изписа С0071, С0047 и С0042. На таблото нищо не свети и при сканиране за грешки с ЕЛМ също нищо не изписва. Някой може ли да ги разшифрова, че в Гугъл излизат различни неща.
| Съб Мар 17, 2018 9:14 am |
patko
Обикновено С кодовете са за ВДЦ модула и АБС. С ЕЛМ не можеш да ги прочетеш. http://jdmfsm.info/Auto/Japan/Subaru/Fo ... er%202009/В секцията CONTROL SYSTEMS, подсекция LIST OF DIAGNOSTIC TROUBLE CODE (DTC) е списъкът с кодовете. За тези системи е нужна диагностична апаратура на дилърско ниво.
21
| Нед Мар 18, 2018 2:30 pm |
slavckc
Skype: slav_ckc
Благодаря колега. Като минавам през Бургас имаш бира от мен Май ще трябва да се разходя до сервиза за да проверя дали са истински грешки или са останали неизтрити в паметта. Само не ми стана ясно, не трябва ли да свети нещо по таблото, ако ги има тези грешки?
| Нед Мар 18, 2018 4:02 pm |
Лампата на таблото е "провери двигателя", демек светка само от грешки с индекс "P".
| Нед Мар 18, 2018 4:06 pm |
patko
Ако има проблем в тези системи ще светне лампата АБС или ВДЦ оff. Това са записани грешки, но не текущи, защото тогава някоя индикация ще остане да свети.
| Нед Мар 18, 2018 6:12 pm |
headless
Регистриран на: Сря Сеп 09, 2015 10:52 am Постове: 16 Местоположение: Варна
Skype: headless_
Автомобил: Legacy '07 H6, Si-Drive
Телефон: 0885383390
Интересна находка, колега, поздравления Потвърждавам, че работи и на фейслифтово Легаси (MY07)
| Вто Мар 20, 2018 2:35 pm |
Саргон
Регистриран на: Съб Мар 10, 2018 7:49 am Постове: 58 Местоположение: Добрич
Автомобил: Outback BP H6
Току що го направих и аз. Резултат е "C----" което означава, че няма грешки, а мотора не работи добре
| Съб Юни 23, 2018 6:48 am |
patko
Хубаво, че няма С. А има ли кодове с Р? Редът е следният: 1. Р...... - кодове за грешки в двигателя. 2. Р...... - кодове за грешки в кутията. 3. С...... - кодове за грешки в АБС, ВДЦ модула.
| Съб Юни 23, 2018 10:48 am |
