 хлабина на клапани при Justy 1.0
Регистриран на: Нед Дек 21, 2008 9:28 pm
Постове: 17
Трябва ми информация за хлабината на клапаните при Джъсти 1.0. Някой беше писал за хлабината при 1.2, но на мен ми трябва конкретно.
Съб Яну 24, 2009 12:09 pm
Постове: 1155
Местоположение: Planet Earth
Valve clearance - inlet: 0.13-0.17 c mm (cold)
Valve clearance - exhaust: 0.23-0.27 c mm (cold)
Justy, 4x4/Van ,, 997 cc, 1987-89, Engine Code EF10,
Ignition data
Justy, 4x4/Van
Ignition system type: CB
Ignition coil make/type: n / a
Supply voltage: 4.1 + Volts with ballast resistor
Primary resistance: 1.34-1.63 Ohms
Secondary resistance: 10700-15000 Ohms
Distributor make/type: Hit/-
Contact breaker gap/air: 0.45-0.55 mm
Dwell angle: 49-55 Deg
Ignition Timing - unleaded: 5  2/750 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 5  2/750 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: O/S/F
Firing Order: 1-3-2
Spark plug make: NGK
Spark plug type: BPR6ES-11
Electrode gap: 1.0-1.1 mm
Fuel System
Justy, 4x4/Van
Fuel type: L/U
Fuel pump type/pressure: Elec/0.09-0.14 bar
Engine idle speed: 750  50 rpm
Fast idle speed: n / a rpm
CO level at idle speed: 1.0-2.0 Vol %
Engine Data
Justy, 4x4/Van
Compression pressure: 9.5-11.0 bar
Oil pressure: 3.3/3000 bar/eng/rpm
Radiator pressure cap: 0.75-1.05 bar/type
Drive belt 1 - size: 9.5x675 KDB675 mm/type
Drive belt 2 - size: n / a mm/type
Electrical System
Justy, 4x4/Van
Alternator output: 45/2500 Amps/eng/rpm
Regulated output: 14.2-14.8 Volts
Battery: 12/36 V/Ah
Starter motor make/type: n / a/12v 0.8kW
Other data
Justy, 4x4/Van
Clutch operation type: Cable
Clutch adjustment: 2.1-4.1/Lever mm
Cambelt failure: Safe
Cambelt Part Number: 13028KA021
Tyre pressures: 2.0(28)f 2.0(28)r bar (psi)
Нед Яну 25, 2009 3:10 am
Постове: 17
Благодаря, колега.
Нед Яну 25, 2009 10:18 am
