US Аутбек/Легаси - спиране на досадното бипкане при key-in
tarambuka3500
Aко имате щатски Аутбек или Легаси (2004-2009), предполагам искате да се отървете от бипкането което се пуска щом сложите ключа. Има и друго бипкане, за пътника без колан. И то може да се махне (перманентно) ето как става: тема на ScoobMods---------------- There are two triggers for the irritating chimes - Non-belted, and key-in-with-door-open. The 20-click method for disabling the seatbelt chimes is documented elsewhere. I've tried this, and it works, but then resets for unknown reasons after a while. So, I sought a more stable solution. Digging around, I found there are 4 wires connected to the driver setbelt latch - two black, one red/white, and one black/white. The two black go to the switch for the chime. The switch is Normally Closed, and Opens when the seatbelt is latched. You can see the black wires by pulling back the rubber cover, as in the fuzzy pic attached. If you want to get rid of the seatbelt chime permanently, clip one of the black wires. If you're more patient than I, you can trace the wires under the seat & try to find a connector to unplug - I couldn't, so good luck. This applies only to the driver side, I have no idea about the pax side. Do not use this mod to drive without the belt latched. If you do, you're an idiot, and at least use it to drive on a deserted road, without passengers, where you can kill yourself & harm no-one else, preferably before you've reproduced.The other warning chime is when you leave the key in with the door open. Simple solution - just pull the connector on the upper left of the steering column. Zip-tie the connector so you don't get a new irritaing noise. A bit hard to get at, but a worthwhile bonding experience. One screw to remove the bottom cover, two to remove the top. ---------------- в оригналната тема има 2 снимки, илюстриращи обясненията.
| Сря Авг 18, 2010 10:56 pm |
ender
Perfect Stranger
Регистриран на: Вто Сеп 11, 2007 11:59 am Постове: 1285 Местоположение: Planet Earth
Skype: nikolay.kapitanov
Автомобил: двойката
Телефон: 0888 831783
tarambuka3500 написа: ....
.... Ето ТОВА ми хареса!!!
_________________ https://www.catalogmachine.com/treasure-bulgaria/catalogs
| Чет Авг 19, 2010 8:26 am |
plaskom
| Чет Авг 19, 2010 8:51 am |
tarambuka3500
това е ясно и тези коментари можем да си ги спестим. от друга страна, да ти дам малко да поседиш в колата ми спрял (чакайки някой), с отворена врата и пуснато радио... след 3тата минута ще искаш да убиеш някого от гадното тинн- тинн-тинн-ТИНН- ТИННН- ТИННН  Индикацията за 'поставен ключ' е задължителна за всички US автомобили поради законови разпоредби. За европейските обаче не е така. Личното ми мнение е, че това е нещо супер досадно, което е полезно да знаем как може да се изключи
| Чет Авг 19, 2010 9:47 am |
plaskom
| Чет Авг 19, 2010 11:37 am |
tarambuka3500
plaskom написа: И моя Аутбек е американски, така че няма нужда да седя в твоя, ама не мога да разбера защо трябва да ти е отворена вратата толкова дълго време като чакаш някой. не искам да разбираш нищо - щом ти е кеф да ти бипка, свиркай си в такт и не разводнявай темата.
| Чет Авг 19, 2010 12:36 pm |
evg3
Регистриран на: Нед Фев 21, 2010 10:05 am Постове: 1217 Местоположение: София, Троян
Ако не им бипка за всяко нещо онея разсеяните хАмериканци ще се утрепат  )))
_________________преди: Impreza 1.8 '94 F4WD Impreza 2.0R '06 Symmetrical AWD сега: Daihatsu Sirion 4WD (full-fledged Justy)
| Чет Авг 19, 2010 3:59 pm |
ender
Perfect Stranger
Автомобил: двойката
tarambuka3500 написа: plaskom написа: И моя Аутбек е американски, така че няма нужда да седя в твоя, ама не мога да разбера защо трябва да ти е отворена вратата толкова дълго време като чакаш някой. не искам да разбираш нищо - щом ти е кеф да ти бипка, свиркай си в такт и не разводнявай темата.  Колеги, не разваляйте боят с кавга, моля!!!  Макар да споделям мисленето на plaskom, все пак отговорността си я носи всеки сам. В случая е подадено инфо, което може да бъде полезно за някой фен...
| Чет Авг 19, 2010 4:11 pm |
Потребители разглеждащи този форум: Google [Bot] и 21 госта |
