 US Аутбек/Легаси - спиране на досадното бипкане при key-in
Постове: 891
Aко имате щатски Аутбек или Легаси (2004-2009), предполагам искате да се отървете от бипкането което се пуска щом сложите ключа.
Има и друго бипкане, за пътника без колан. И то може да се махне (перманентно)
ето как става:
тема на ScoobMods
There are two triggers for the irritating chimes - Non-belted, and key-in-with-door-open.
The 20-click method for disabling the seatbelt chimes is documented elsewhere. I've tried this, and it works, but then resets for unknown reasons after a while. So, I sought a more stable solution. Digging around, I found there are 4 wires connected to the driver setbelt latch - two black, one red/white, and one black/white. The two black go to the switch for the chime. The switch is Normally Closed, and Opens when the seatbelt is latched. You can see the black wires by pulling back the rubber cover, as in the fuzzy pic attached. If you want to get rid of the seatbelt chime permanently, clip one of the black wires. If you're more patient than I, you can trace the wires under the seat & try to find a connector to unplug - I couldn't, so good luck.
This applies only to the driver side, I have no idea about the pax side.
Do not use this mod to drive without the belt latched. If you do, you're an idiot, and at least use it to drive on a deserted road, without passengers, where you can kill yourself & harm no-one else, preferably before you've reproduced.
The other warning chime is when you leave the key in with the door open. Simple solution - just pull the connector on the upper left of the steering column. Zip-tie the connector so you don't get a new irritaing noise. A bit hard to get at, but a worthwhile bonding experience. One screw to remove the bottom cover, two to remove the top.
в оригналната тема има 2 снимки, илюстриращи обясненията.
Сря Авг 18, 2010 10:56 pm
Perfect Stranger
Постове: 1285
Местоположение: Planet Earth
Skype: nikolay.kapitanov
Автомобил: двойката
Телефон: 0888 831783
tarambuka3500 написа:
Ето ТОВА ми хареса!!! :mrgreen: :mrgreen: :mrgreen:
Чет Авг 19, 2010 8:26 am
Постове: 2780
Всички предупредителни звукови и светлинни индикации в автомобила са монтирани от производителя за да предупреждават водача, че нещо не е наред. Не разбирам защо трябва да се премахват. Може би също трябва да си махнем и всички предупредителни светлини от таблото за да не ни досаждат, като за отворена (не добре затворена) врата, налягане на маслото, ръчна спирачка и т.н. И да си караме на спокойствие :mrgreen: :mrgreen: :mrgreen:
www.plaskom.com
Чет Авг 19, 2010 8:51 am
Постове: 891
plaskom написа:
това е ясно и тези коментари можем да си ги спестим.
от друга страна, да ти дам малко да поседиш в колата ми спрял (чакайки някой), с отворена врата и пуснато радио...
след 3тата минута ще искаш да убиеш някого от гадното тинн-тинн-тинн-ТИНН-ТИННН-ТИННН :-D
Индикацията за 'поставен ключ' е задължителна за всички US автомобили поради законови разпоредби. За европейските обаче не е така. Личното ми мнение е, че това е нещо супер досадно, което е полезно да знаем как може да се изключи :smt023
Чет Авг 19, 2010 9:47 am
Постове: 2780
И моя Аутбек е американски, така че няма нужда да седя в твоя, ама не мога да разбера защо трябва да ти е отворена вратата толкова дълго време като чакаш някой. А има и доста по-досадни неща, като на служебния ми автомобил например - като караш с повече от 120 км/ч постоянно бипка и свети лампа на таблото че караш с превишена скорост. Е това е наистина досадно :mrgreen: :mrgreen: :mrgreen:
www.plaskom.com
Чет Авг 19, 2010 11:37 am
Постове: 891
plaskom написа:
не искам да разбираш нищо - щом ти е кеф да ти бипка, свиркай си в такт и не разводнявай темата. :smt023
Чет Авг 19, 2010 12:36 pm
Постове: 1217
Местоположение: София, Троян
Ако не им бипка за всяко нещо онея разсеяните хАмериканци ще се утрепат :))))
преди:
    Impreza 1.8 '94 F4WD
сега:
Чет Авг 19, 2010 3:59 pm
Perfect Stranger
Постове: 1285
Автомобил: двойката
plaskom написа:
Колеги, не разваляйте боят с кавга, моля!!! [-X [-X [-X
Макар да споделям мисленето на plaskom, все пак отговорността си я носи всеки сам. В случая е подадено инфо, което може да бъде полезно за някой фен...
Чет Авг 19, 2010 4:11 pm
