(2) 15x7 rally with BFG P215/60R15 = 95.56 lbs.
(2) 15x8 rally with M/T 26x10.5-15 = 93.70 lbs.
Total weight = 189.26 lbs
e.t. and mph =
[email protected]Test 2
(2) 15x4 rally with M/T 26x7.5-15 = 70.86 lbs.
Total weight = 164.56 lbs.
e.t. and mph =
[email protected]Test 3
(2) 15x7 Center Line with BFG P215/60R15 = 70.46 lbs.
(2) 15x8 Center Line with M/T 26x10.5-15 = 64.10 lbs.
(4) Center Line center caps = 0.96 lb.
Total weight = 135.52 lbs.
e.t. and mph =
[email protected]Test 4
(2) 15x4 Center Line with M/T 26x4.5-15 = 42.12 lbs.
(2) 15x8 Center Line with M/T 26x10.5-15 = 64.1 lbs.
Total weight = 107.18 lbs.
e.t. and mph =
[email protected]Total weight reduction = 82.08 lbs.
Total performance gain = -0.111 sec, +1.12 mph
Weight Comparo
Traditional Rally Wheels (Wheel Vintiques)
Wheel Material Size Weight (lbs.)
Rally Steel 15x4 18.78
Rally Steel 15x7 23.68
Rally Steel 15x8 27.23
Options
Flat "disc brake" center cap 1.12 lbs.*
15-inch chrome trim ring 1.28 lbs.*
*Note: Per NHRA rules, for testing we did not run rings or caps. For street cars, add 9.60 lbs. for caps/rings.
Lightweight Wheels (Center Line)
Convo Pro Aluminum 15x4 9.64
Convo Pro Aluminum 15x7 11.13
Convo Pro Aluminum 15x8 12.43
Options
Center Line center cap 0.24 lb.
Tires
Brand Type Size Weight (lbs.)
BFG Radial T/A P215/60R15 24.10
M/T Sportsman 26x7.50-15 16.65
M/T E.T. Front 26x4.5-15 11.42
M/T E.T. Drag 26x10.5-15 19.62
M/T Inner tube* #9552 4.80
*Note: We did not run tubes for testing, but if you choose to run tubes in the slicks, add 9.60 lbs.
Май разликата е минимална
_________________"ladies and gentlemen the wing is back
